Just talked to the seller- engine last ran 3 months ago, no smoke, it's under a tarp. Guy seemed like a good person. If I get $150 by the end of the week, it's as good as mine.
I enjoy cutting my.own grass too much, but I do have a pile of brush that needs removal. 😀joesregalproject said:Seller contacted. I think I'm gonna buy it. I just need some quick money. Anyone need their grass cut?![]()
tetomas said:The block on the 95 is not machined for a mechanical fuel pump. The mounting flange is cast but the hole for the pump pushrod is not bored, and the bolt holes are not drilled or tapped, so I would plan on an electric pump and regulator. Sounds like a deal though, I would grab it up.
pontiacgp said:you can put a carb on it and remove the computer. If your distributor is computer controlled you'll need one that is not. That 95 should have a serpentine belt so you will probably need an adapter for the alternator.
