Is Windshield Primer Necessary?
MrSony
6,790
6,673
Des Moines, Iowa
Is it necessary? Can I just use any old primer? What's so special about that 20-60$ bottle?
Nov 4, 2012
5,997
12,668
You mean the primer for the urethane? Yes, its necessary if you want a good bond. The urethane should be sold a system with a primer, kinda like PVC cement. They do make primerless urethanes but they aren't as good as one that uses a primer.
melloelky
4,136
9,486
mass
Unless you're going over a paint or bare metal you don't need primer. You can put new urethane on top of the old cut urethane
MrSony
6,790
6,673
Des Moines, Iowa
I ended up buying two bottles. It's safe to put over bare cleaned metal, yes?
melloelky
4,136
9,486
mass
it's not designed to go over a large area of bare steel.any spot on the glass where the blackout is damaged or there isn't any at all.small scratches on the pinch welds and the like yes.
