Looking for one of these. Making the change from Edelbrock to Holley (I have everything minus the intake) Someone bought the last one on eBay. (Example Photos). I am Willing to pay up to $150. I am located in Michigan closer the better. Part #701R-22 / 300-22. Buick 3.8/4.1L V6 only. Any leads helpful.
Yes, i currently have the Edelbrock. Mainly Reason is. They don't have a 4bbl carb under 500cfm and for the engine is almost all stock... It is still way too much for it. The 2bbl carb originally was in the mid-300s I believe. I am that kind of guy who needs to have everything "matching" brand-specific. haha, I looked 2 years for the V6 Valve covers, and I got a 390cfm 4bbl from a friend. But I'd like to have the intake. Not sure on the improvements, not much info out there on that.
I assume that Street Dominator is single plain, all them are, I believe. Your Edelbrock is a dual plane, correct? Apparently less low end torque is the goal?
If this is your current intake I will bet that it perform better than the Holley you posted
It is a true dual plane since the divider is not cut down like the Holley and it is a square bore carb bolt pattern like your 390 instead of a spreadbore design with dual bolt pattern.
