ISO/Wanted. Holley V6 Street Dominator Intake
CrammerGram69
437
143
SW, Michigan
Looking for one of these. Making the change from Edelbrock to Holley (I have everything minus the intake) Someone bought the last one on eBay. (Example Photos). I am Willing to pay up to $150. I am located in Michigan closer the better. Part #701R-22 / 300-22. Buick 3.8/4.1L V6 only. Any leads helpful.
Holley Street Dominator aluminum intake Part#300-22 casting number 701R-22.jpg
9,614
12,683
Are you saying you currently have an Edelbrock intake and want to swap it for the one posted, if so what is the advantage of going with the Holley?
CrammerGram69
437
143
SW, Michigan
Yes, i currently have the Edelbrock. Mainly Reason is. They don't have a 4bbl carb under 500cfm and for the engine is almost all stock... It is still way too much for it. The 2bbl carb originally was in the mid-300s I believe. I am that kind of guy who needs to have everything "matching" brand-specific. haha, I looked 2 years for the V6 Valve covers, and I got a 390cfm 4bbl from a friend. But I'd like to have the intake. Not sure on the improvements, not much info out there on that.
9,614
12,683
I have always ran Edelbrock intakes with Holley carbs and they work well together.
8,823
7,775
I assume that Street Dominator is single plain, all them are, I believe. Your Edelbrock is a dual plane, correct? Apparently less low end torque is the goal?
CrammerGram69
437
143
SW, Michigan
Not sure, haha. I think the Holley is dual too? I prefer the quality of better appearance. lol. The eng is complete stock anyways.
CrammerGram69
437
143
SW, Michigan
the last edelbrock i had was a 750. way too big for the engine. the eng is already converted to 4bbl. No adaptor needed
9,167
15,344
Before Edelbrock got into the carb game the combo most ran was a Edelbrock intake with a Holley. That's what I'm currently set up with.
  • Wow
9,614
12,683
If this is your current intake I will bet that it perform better than the Holley you posted
It is a true dual plane since the divider is not cut down like the Holley and it is a square bore carb bolt pattern like your 390 instead of a spreadbore design with dual bolt pattern.
'86-87 Turbo Buicks have single plane intakes... they drive just fine off boost.
N/A Buick V6s don't make enough power to notice a few foot pounds difference.
