hello all
I have 85 442
Trans was done, TransGo shift kit, Super Servo, TCI breakaway Converter, sits behind an olds 355 and 4.10's in the rear on a 255/60/15 tires.
Here's my issue
The trans shifted okay at first, not as great as my GN with a CPT HiTech shift kit, but ok.
Well one day it didn't wanna shift at all until very very late, took it back to the trans shop, they pulled the pan with me there, pulled the valve body looking for something wrong, couldn't find anything.
Pulled the governor and says to me the spring is out, not in the pan, who knows what happened to it, I almost felt like he was pointing the finger at me about it, but that's not important.
Anyway, he grabs a spring from his junk chore, from what he said looked like a V6 governor spring and threw it in there.
Well it shifts now, but 1st to 2nd gear is 10 mph
2nd to 3rd 18-20 mph
Od shifts around 35 or so mph
Now I can't help to think the spring he used is no where near right.
I found TCI makes a spring for the governor for the GN trans.
So I'm asking, could I use this spring?
Is the 442 spring my only choice?
If so, where could I acquire one?
Because I changed the rear end ratio, does the governor need to be modified in any way?
I ended up purchasing the same shift kit I have for my GN, although not here yet,
Would this help fix my problem?
I really appreciate any and all help about this.
I rarely drive the car because of this issue, it's fine if you manually shift, I'd like to get this right, to enjoy it, and if I needed to sell her, it would be right for the next buyer.
Thank you again
I have 85 442
Here's my issue
Thank you again
