I am currently in the process of buidling a sbc 400 and I ordered a Comp Cams Big Mutha Thumpr cam .486 ...The cam installs smoothly but when I rotate the engine I can tell the cam is binding on something and it locks the rotating assembly. I put the crankshaft sprocket dot at the 12 o clock position and the cam sprocket dot at 6 o clock....i put cylinder 1 at tdc which places the dot at 12 o clock position i also notice that cylinder 6 is at the top too...does this sound like i have the cam timing incorrect???
