Jack Stand Placement
sldwys
126
66
Need to have car on jack stands for a week.
Ive looked at the manual and searched the forums. I’m still confused.
Where exactly should I place jack stands? The driver side has two holes where the frame is wide and the passenger side has one hole? I assume for factory jack? Do I just use the widest part behind front wheel?
sldwys
126
66
Passenger side
565bbchevy
9,590
12,611
Michigan
After that.
sldwys
126
66
Pic is hard to see. Just need to know if I stay on the wide part of frame behind front wheel will I be ok?
565bbchevy
9,590
12,611
Michigan
Driver's side looks solid, passenger side is hard to tell it looks like only one edge is touching.
Are you raising it more?
sldwys
126
66
Yea I just took out stock jack. Didn’t realize it went in the hole for body mount. Just going to try to stay in that area.
melloelky
4,136
9,486
mass
you're in the rite area,shake the hell outta the car before you get under it to be sure.
