I stumbled across this article on google and I was wondering if anyone has done any measuring or can validate this info on 3.900 crankshafts in ls blocks.
I’ve read/heard before that 4.000 stroke causes the piston rings and the piston skirt to swipe the bottom of the cylinder which causes premature wear/failure. This article is saying that with a 3.900 crank (which is kind of an odd stroke) you don’t get that rub on the bottom of the cylinder.
I asked two Representatives about this info on the phone but they both said they haven’t heard this before. I’m curious if a 3.900 crank is more safe because I’m building an LQ9 turbo motor and replacing the crank so if I can safely stroke it while I have it torn apart I would like to.
http://blog.jepistons.com/different-strokes-choosing-the-right-stroker-crank-for-your-ls
