My 2003 Grand Cherokee with the 4.7 developed a charging problem on my 40 minute drive to the office this morning. I notice the volts on the gauge dropped but no warning to check gauges lit up until the volts got into the red. On a pervious Jeep the warning came on as soon as the alternator died. I made it to my friend's business where he sells and installs stereos etc. I put the battery on charge and started the Jeep when the battery was at 60%. The alternator wasn't charging so I played with the 2 wires that plug onto the back of the alternator. The alternator started charging so I removed that connector and everything seemed to be clean and the wires were in good shape. I plugged the 2 wire connector back in and the alternator is charging like it should and even with moving the two wires around. With the rear defogger on, headlights on and ac on high at idle it's charging 13.4-.6. I had to top up one cell in the battery and the battery seems to be fine. I know alternators do not work intermittently and Jeeps are famous for electrical glitches so I'm wondering what I may be in for. The voltage regulator control on my Jeep is in the brain so I hope that isn't an issue but I did research a work around for that issue when my previous Jeep's alternator died just in case it wasn't the alternator.
I called the local alternator guy this morning and he has one for my Jeep but I don't want to buy it if I don't need it, what do you guys think?.....
