Jegs crossmember for El Camino?
Ugly1
1,628
1,354
Lost in the woods of NH
Bought this one for mine when I put the T-5 in. Bolts right in 1981 ElCamino
x75
Sep 23, 2018
75
33
trying to fit this exhaust
Ugly1
1,628
1,354
26.5”wide with the points you have marked. The “pipe” areas is 7”wx4”H(each) and the transmission mount area is 13”wide area of box tubing. This leaves about a 1” to 1.5 in gap from the floor. If going with 2.5” or 3” pipes should leave enough space if properly installed
x75
Sep 23, 2018
75
33
wow, thank you so much. I will be under the car tomorrow to check dims while installing a mini-starter.
Pretty sure I'm ordering the Summit crossmember ASAP
will post results/photos
