Anyone use the new Copper Clad Aluminum jumper cables? Any issues? I prefer solid copper but they are getting hard to find.
That's another issue. I am liking the Die Hard Platinum kit. Solid copper, nice clamps, 4ga, 20ft, in a carry case. No one has it not even Sears. EDIT: And made by Schumacher.Crappy clamps
Can’t say I used their cables, but I had an old Sears die hard battery here in Canada, from the early 2010’s.That's another issue. I am liking the Die Hard Platinum kit. Solid copper, nice clamps, 4ga, 20ft, in a carry case. No one has it not even Sears. EDIT: And made by Schumacher.
Here in Ontario it’s illegal to use aluminum wiring in houses.I just still stick to my old copper ones. Then again I refuse to use that aluminized wiring in work in the houses too.
Just like I hate ls motors.
Old stuff is just plain better. I can pull a 50 year old inline truck out of a field and it'll run with gas, although oil should be changed too. I highly doubt you could park a new car in a field for 40 years and make it start with nothing but gas after.
And now the code is for arc fault circuit breakers. That is, when an arc is detected, it trips the breaker just as a ground fault breaker would. And are THOSE expensive MF's. I may have to settle for the CCA wires as the pure copper ones are going for hundreds of dollars. Not to sit in the trunk for years waiting to be used. The Die hard platinum is a great bargain but no one has it.Aluminum wire is not allowed in houses because thermal expansion would cause the breakers and outlets screw terminals to become loose over time. Loose connections would cause arcing,
Well that and the fact, if you strip wires and gouge the wire even slightly, the resistance goes way higher than it would on copper, causing heat and potentially fire from the amperage being pulled.Aluminum wire is not allowed in houses because thermal expansion would cause the breakers and outlets screw terminals to become loose over time. Loose connections would cause arcing, the arcing in less than sealed outlet boxes or breaker panels would cause house fires. This issue only affected solid, single strand wire as multistrand wire is thin enough to deform when compressed by a screw terminal.
All these issues are not a problem for a jumper cable, as it is multistranded wire and it will be crimped onto the clamps. The copper-clad wire could actually be a good replacement to solid copper wire in THIS application.
