Jumping power window switch
565bbchevy
9,590
12,612
Michigan
Can I use a couple wires directly off a battery to bypass the power window switch and make these windows go up, there is no power to the car which I haven't investigated yet but I want the windows up since this will be outside.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Edit, plug in the switch, there should be a blue and black wire coming from the motor. Take a battery and hook the blue to 12V and the black to ground.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
yes, to bypass the switch, to go up power on blue, ground on brown, ........on that connector positive on blue/white and negative on brown for passenger window
565bbchevy
9,590
12,612
Michigan
I just put the battery positive on the pink wire on the backside of the driver's switch and grounded the battery to the drivers door and both windows went up from the driver's switch. Thanks to all that replied.
