Working great for me. Not sure why more people don't use it.
Agreed. Why do suppliers continue to only provide the crappy stock rubber hose / hose clamp option?Is there any difference between this and a GN hanger with any pump of your choice?
I was hoping to see that this has threaded fittings on the supply side or something that makes connecting fittings more friendly.
You can get them with a 340lph pump too 😉Cause most of us need bigger pumps.
I used a stainless steel Swagelok fitting to go onto the sender and convert to AN thread. Same on body side fuel line. Those are good for 5000 psi IIRC.Agreed. Why do suppliers continue to only provide the crappy stock rubber hose / hose clamp option.
Best case scenario would be a standard fuel line fitting as shown below. Not threads for overpriced AN fittings with braided line.
If you can find a 4.3L fuel injected Monte, they have threaded fittings on the sending unit. I still have one if you're interested.Is there any difference between this and a GN hanger with any pump of your choice?
