i would go with a 3 row and for that extra little bit maybe an oil cooler. i have heard the oil coolers get you a little cooler but i havent had one yet. just an option.
84Hurst/Olds said:Well you know.... That is the radiator that was in the car when I purchased it five years ago. I think I will just go to the parts store and get a new stock radiator. Hopefully that clears me up.
You do realise, if you don't have any coolant in there at all, even if you don't drive it in the winter, your block can crack? I know. I've done it79loserbluebu said:I'm using a Champion eBay 2 row radiator in my Malibu, with a 180°thermostat and water instead of antifreeze since I don't drive it often or in the winter. Cools amazing, definately runs under 180°. Runs hotter on the highway but that's because I'm at 3k RPM continuosly with an electric fan that doesn't cover the radiator all the way. Super happy with that radiator and if I need another one ever, that's where I'll be getting it from.
454muscle said:You do realise, if you don't have any coolant in there at all, even if you don't drive it in the winter, your block can crack?79loserbluebu said:...water instead of antifreeze since I don't drive it often or in the winter...
