I can turn it over and start it with a push button starter bumper, but not the actual key...
The purple wire running to the starter is giving power to the starter, and lights on the dash lights up but seems as if the ignition switch is out...
Is there any troubleshooting technique I can use to test the ignition switch, or a fuse that powers the ignition switch I can check ?
