im having a problem with my kick down cable. it seams to be getting stuck sometimes when i step on the gas it on a edlebrock carb 1406 i used a after market bracket to make it work from eldebrock
mc87ss said:im having a problem with my kick down cable. it seams to be getting stuck sometimes when i step on the gas it on a edlebrock carb 1406 i used a after market bracket to make it work from eldebrock
not real sure ill post pic later the cable is after market becuz the other one broke when i changed the trans out. yea the trans is a th 350DrRansom442 said:mc87ss said:im having a problem with my kick down cable. it seams to be getting stuck sometimes when i step on the gas it on a edlebrock carb 1406 i used a after market bracket to make it work from eldebrock
Since you called it a kickdown and not a TV cable am I to assume you have a th350 or th400 and NOT the 200-4r? DiD you reuse your old cable or buy a brand new cable? Do you have the p/n of the kickdown bracket, so we can be certain it's right for the application.
