Kilduff Machine
565bbchevy
9,590
12,612
Michigan
I knew guys on here were running their lightning rod style shifter but I never looked at what other styles they have, interesting selection for sure.
Reactions: 4 users
Tony1968
2,313
5,099
NW Indiana
I know this is older but I really dig these shifters
Drkuhar
507
896
Girard, IL
I have the three stick lightning rod. The kilduff shifters use b&m cables and linkage hardware so since i was replacing a b&m it was a really simple swap out. It is well made. There is a couple of things i dont like. The housing is not sealed tight so if you have the led light inside it shines out everywhere not just the prndl cutouts. Mine is in a console that i had to modify but it solved that problem. The other issue is there is no positive stop for park. The check ball and spring detent allows you to actual go past park and pull the cable tight. Function wise in gear and shifting it works smoother than original lightning rods i used years ago and you can down shift and up shift with the levers
