Landau to coupe conversion
Ratchet
168
What is needed to remove and convert an 80 Malibu Landau side windows and trim to the look of the plain coupe?
gnvair
869
You need:
left and right quarter glass for non landau
B pillar molding/trim for non landau
lower quarter glass exterior trim for non landau (this goes on before the glass)
The interior B pillar trim for non landau
Remove the additional metal piece that is welded to the B pillar
and remove all the studs and clips that hold the landau trim around the top.
  • Love
Ribbedroof
"That wagon guy"
4,150
Wellston, OK
You need:
Also will need non-Landau sail panels (upper C pillar, above package tray)
Ratchet
Thread starter
Jan 10, 2018
168
Are the parts available (landau to coupe conversion) on the aftermarket or are the parts only available used? Either way, what/who are the sources?
Ratchet
Thread starter
Jan 10, 2018
168
The only things available new are the interior upper b pillar trim and the exterior lower glass trim. Everything else would have to be sourced used.
Thanks, I'm going to check with Dixie Restoration and see what all they have as well.
G-Body Performance Upgrades
