Has anyone installed there urethane front end spoiler on a regular Cutlass? I am looking for some pictures of it so I know what to do when I install mine. I am not sure about the J channel piece. Thanks in advance!
I have one that I am prepping for paint now. At first I was not impressed with the look of it, but with a little sanding it has come around. I plan to use the J channel, it is correct as far as I can tell. OE was fastened on the same way. Unfortunately it will be a while until it will be done as the car is completely disassembled for paint.
Its a bad pic once I get it outside I will snap some before and after it is painted. I am not using the J-channel as I don't like it. I had to d some trimming here and there but am happy with it. I have the 2 inch hood scoop from Lauren which I cut the back open and plan to make it a cowl scoop. I have just been lazy to get her running again with a 750 carb and a new distributor and tuning it.
