Leaking oil
Discussion in 'Engine / Swaps etc.' started by LukeZ, Apr 10, 2017.
  1. LukeZ
    LukeZ Master Mechanic
    Apr 24, 2015
    434
    171
    Delaware
    "leaking" might be an understatement. Its a little worse than that. She leaked a few drops every now and then if I let the car sit for a month while I'm at school, but its a different situation now.
    This is a recent problem, within the last couple weeks. Started after I swapped my intake. I just want to narrow this down to what it might be so that I can get this fixed.
    I know Texas82GP gave me a good idea awhile back about hooking my crankcase breather tube up to my new heightened air cleaner. I haven't gotten around to that yet. Right now its just sticking out of the valve cover with a foam filter on the end. Is that a problem? Does it need vacuum drawn by the air cleaner or something? Would this cause a leak? The foam doesn't even have a lot of oil on it.
    I don't think it has anything to do with the PCV. It's sucking really good and I have it connected to to carb.
    It's not the oil filter or oil drain plug.
    The intake is on tight, so I don't think that's it either.
    I just tightened my valve cover bolts (they weren't that tight. The wrench was easy to turn) so hopefully that helps. I actually snapped one so that really sucks. I couldn't mess with it anymore because the university maintenance guys came up and told me that you can't work on your car on UD property.
    Are valve covers supposed to have gaskets? Maybe mine had them before but they just corroded away to nothing. Can I use RTV to seal them up when I go home later this week?
  2. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,774
    2,949
    Kitchener, Ontario
    valve covers need gaskets and without them the oil would be pouring out and very visible. Did you use a gasket for your distributor and check the intake at the back and front to make sure it's not leaking there. You might want to pick up a book on engines and read that through so you have a better idea on what you are doing instead of having to ask about issues after the job is done.
    • Like Like x 2
    • Agree Agree x 1
  3. L67ss
    L67ss Royal Smart Person
    Dec 8, 2016
    1,395
    215
    Put cardboard under the car to get a good idea where the leak is
    • Like Like x 1
  4. LukeZ
    Apr 24, 2015
    434
    171
    Delaware
    Yes, the distributor has a gasket. I didnt get a good look at the back of the intake so Ill check that out next time I see my car. The oil isnt gushing out of the valve covers while I have the car running or anything. L67ss, Ill try the cardboard thing this weekend. Like I said, the car dripped before, but now its at the point where its concerning me. I checked the oil level and its still at full.
    One funny thing is the guy at Advanced Auto told me that my car only takes 4 quarts of oil (according to the computer) the last time i bought oil to do a change. They never mentioned that to me before, and I always buy the 5 quart containers. I never paid attention to it in the past, but maybe I have too much oil?
  5. Texas82GP
    Texas82GP Comic Book Super Hero
    Silver
    Apr 3, 2015
    4,221
    3,243
    Spring, Texas
    Your car takes 5 quarts of oil. You need valve cover gaskets for sure. Also, you will have to extract the broken bolt. Without gaskets and all the bolts, the valve covers will leak. You could put them on with just RTV but I advise against it.
    • Like Like x 1
    • Agree Agree x 1
  6. LukeZ
    Apr 24, 2015
    434
    171
    Delaware
    I thought it was 5. Thanks. And the way it looks, the threaded stud that broke is like a part of the head. The valve covers slide on over the 4 studs, and the bolt just goes on over the lip of the valve cover to hold them down. The stud broke in half, so now there is only a little bit left for me to get the bolt to grab on to, once I get the broken part of the stud out of the bolt. Jeez, theres always something lol
  7. Texas82GP
    Silver
    Apr 3, 2015
    4,221
    3,243
    Spring, Texas
    It's a stud threaded into the cylinder head. The valve cover goes over the stud and then is retained by a nut. You need to extract the broken stud and replace it. I would get a nice used stud and nut from a member on here.
    • Like Like x 1
  8. pontiacgp
    Mar 31, 2006
    21,774
    2,949
    Kitchener, Ontario
    it's 4 quarts without the filter and 5 quarts with a filter
    • Like Like x 1
    • Agree Agree x 1
  9. TURNA
    TURNA Comic Book Super Hero
    Jul 24, 2009
    3,860
    1,814
    Socialist NY
    When you put the intake on did you use the rubber gaskets for the front and rear that came with it or did you use an RTV or both?
  10. LukeZ
    Apr 24, 2015
    434
    171
    Delaware
    just rtv
Loading...
Similar Threads - Leaking oil Forum Date
water pump back plate leaking Engine / Swaps etc. Jun 8, 2014
Leaking?? Engine / Swaps etc. Feb 28, 2013
Head leaking issue Engine / Swaps etc. Sep 2, 2012
header collectors leaking like crazy Engine / Swaps etc. Oct 30, 2010
307 carb leaking Engine / Swaps etc. Jul 6, 2010
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
