Leaking Valve Covers
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,186
9,378
Kitchener, Ontario
#1
I have a problem with the driver's side valve cover leaking at the back just a bit of oil that ends up on the the exhaust just past the collector. The covers are the stock center bolt. I have the fel pro blue gaskets and I'm wondering if the cover may be warped, I don't think it's from over tightening. Anyone have any suggestions or fixes? Thanks
A
awdblazer
261
32
#2
put valve cover load spreaders on
565bbchevy
565bbchevy
5,824
4,801
Michigan
#3
M
Michael Watts
253
103
#4
I would check if its warped.Then fix them with a file. or replace them .And put a thin coat of RTV on your valve cover gasket.I usually Fel Pro thick rubber impregnated cork gasket on mine .Never had an issue afterword.
pontiacgp
pontiacgp
Mar 31, 2006
24,186
9,378
Kitchener, Ontario
#7
it's just a valve cover and gasket and there should not be a need to put on a layer of rtv. I like keeping things that should not be complicated as simple as possible. I'll look into the Fel Pro thick rubber impregnated cork gasket
buick7332
buick7332
149
194
N.E. Philadelphia area
#8
I've never had good luck with cork gaskets, I've always used rubber but they are getting hard to find.
565bbchevy
565bbchevy
5,824
4,801
Michigan
#9
I use Moroso blue rubber gaskets for my BBC and now for my SBC but I am also running aluminum fabricated valve covers with a billet rail.
455'ed80Regal
455'ed80Regal
398
126
Lincoln, MO
#10
I'm thinking it's the rocker cover as those should never leak when using those gaskets.
Similar threads
