Leaking Valve Covers
20,391
I have a problem with the driver's side valve cover leaking at the back just a bit of oil that ends up on the the exhaust just past the collector. The covers are the stock center bolt. I have the fel pro blue gaskets and I'm wondering if the cover may be warped, I don't think it's from over tightening. Anyone have any suggestions or fixes? Thanks
9,590
12,612
Michael Watts
418
201
I would check if its warped.Then fix them with a file. or replace them .And put a thin coat of RTV on your valve cover gasket.I usually Fel Pro thick rubber impregnated cork gasket on mine .Never had an issue afterword.
20,391
it's just a valve cover and gasket and there should not be a need to put on a layer of rtv. I like keeping things that should not be complicated as simple as possible. I'll look into the Fel Pro thick rubber impregnated cork gasket
buick7332
350
589
N.E. Philadelphia area
I've never had good luck with cork gaskets, I've always used rubber but they are getting hard to find.
9,590
12,612
I use Moroso blue rubber gaskets for my BBC and now for my SBC but I am also running aluminum fabricated valve covers with a billet rail.
455'ed80Regal
467
211
Lincoln, MO
I'm thinking it's the rocker cover as those should never leak when using those gaskets.
