MONTE CARLO leftover AC hoses
KarateCrotch
Jul 30, 2020
50
10
8
Los Angeles
what do i do with these useless hoses i took out my AC and have these left over hoses i tried to take the orange one out from the water pump but coolant leaked out, do i cap the water pump with something and also the black hose that was attached to the ac that leads to the top of the engine, can i get rid of that one too?
and the metal line for the ac it connects to the refrigerant thing i’ll post pics with this, what do i do with that i’ve only taken out an ac out of a gbody once and don’t really remember the whole process.
565bbchevy
9,611
12,670
Michigan
For the heater hoses you can cap the intake and water pump fittings but the cleaner way is remove the fittings and install pipe plugs with sealer.
The AC hoses can all be removed when taking off the AC compressor and you might as well remove the condenser in front of the radiator to get better airflow.
KarateCrotch
Jul 30, 2020
50
10
8
Los Angeles
the condenser is out which one is the compressor?
565bbchevy
9,611
12,670
Michigan
KarateCrotch
Jul 30, 2020
50
10
8
Los Angeles
and also do you know what size pipe plugs would be good?
565bbchevy
9,611
12,670
Michigan
I don't really play with stock stuff but I think they are 1/2" NPT
This is the style I use so they can be flush mounted.
KarateCrotch
Jul 30, 2020
50
10
8
Los Angeles
i took out the compressor about the belt that was around, do i just take off the belt and that’s it or do i need a smaller one to replace it
mikeluscher159
29
Make sure you loop the two heater ports together, don't just blank them off
