So I'm putting together a list with some options. Not entirely sure with route I want to go. So, I figured I'd ask you guys for some insight/experience.
I currently have a Th350 with an unknown convertor.
The trans was in the car when I got it. Trans feels good. No slipping, shifts nice and firm. Fluid looks and smells good.
Only issue I have is when I went swapped to EFI on the Ol' LS I lost my kickdown and the shifter sucks but I will be making a separate topic about that.
So my current idea is to keep my current trans, get a new budget converter and possibly a cheapo manual valve body
Summit recommends a 3000rpm Stall for my cam.
Jegs has a super budget converter that is pretty popular with the "sloppy" crowd. Has good reviews and very affordable at $180 with and advertised stall of 2700-3000 RPM.
Summit has one for $200 with an advertised stall of 2800-3200 RPM. I haven't done too much research on the Summit one to see reviews or who makes it for them.
Then I have been looking at TCI manual valve bodies. Pretty much $240-$270 depending on forward or reverse pattern, which on don't really know the benefits of each.
which puts us at lets say ~$500 parts plus fluid and filter.
Option 2: At much higher cost is to go 4L80.
When I went to EFI I went with the Termi X MAX because I wanted DBW and the capabilities of controlling the 4l80 in the future.
I know pretty much all the PROs go toward the 4l80 with strength, overdrive and such but it comes at a high cost.
Trans- ~$900
Holley $4l80 harness.- $200 (when I got the termi I got without the harness to save some cash at the time.)
New drive have shaft- $400ish.
Converter and Flex plate. -$500+
I would like to at least do a Transgo HD2 kit -$140.
Fluid and Filter- $100ish.
and lastly mod my current Jegs cross member.
So That is roughly $2,500 for a super stout trans.
For Both options I need a new shifter and I also want to do a rear mounted trans cooler with fan.
So my things is for the time being as a head/cam LS would I be okay with the TH350(with the converter & MVB) for street/strip fun or should I just leave it as it is and save for the 4l80 so it can be ready for the boost later.
Trans- ~$900
