Level 1 build thread....
88MONTESS
189
334
Man I’ve seen some of the build threads in here.. They are extreme! This thread will probably be bit boring compared to those.
Not at all new to Gbodys but planning on keeping this one carbed.. Definitely new to that. Some recent pics
Reactions: 10 users
19,990
Factory sunroof???
Nice!
9,591
12,612
IMO if you are going to run a carb I would run your feed line to a regulator that is in front of the carb and then flip your fuel line around, that way you are not fighting G force to get it in the carb and then you can also run higher pressure to the regulator.
88MONTESS
189
334
Ok on to some cleaning... Car sat for at last 7 years prior to me buying it. So I will try to save what I can...
Astroroof leaks
Rear window leaks
Windshield has a leaky spot also 🤷🏿‍♂️
88MONTESS
189
334
Not reusing the factory rear seats and I’m not even sure what the fronts came out of. Do they look familiar to any one?
Center console is beat but I’m going to try to save it
88MONTESS
189
334
Headliner also was wasted so I removed it. I want to Utilize the factory console so I had to make a plate to raise the shifter that I plan on using. Trans is reverse manual so
the factory shifter isn’t going to cut it.
8,806
7,746
Man are those rad hoses are tiny, obviously the LS are easy to cool. Sucks that so much leaks on this car, I imagine the floor is toast. Obviously they did the LS swap as cheaply as possible, big Holley carb and factory exhaust manifolds. I assume a reverse manual TH350?
