Hey everyone! I'm new to the chat. I have an 83 el camino with an 5.3 LM7 swap. I have an LS6 intake, LS6 injectors and aftermarket fuel rails. Here's my question. If I haven't started the car in a week a or so, when I go to run the car on it takes a little longer to crank and turn over than normal. However, if I turn on the ignition and let the fuel pump run for MAYBE a second then crank it the car starts right up. The car drives perfectly fine. No misses or lack of power. I'm a bit of a novice and I'm learning as I go on this car (I didn't build it). The issue is I don't have a schradar valve to test the fuel pressure so I'm guessing I have to buy a cheap in line fuel pressure gauge? My question is do any of you think I have a very very very small/slow fuel pressure leak or am I overthinking it and the electric fuel pump just need a second to build fuel pressure before I crank the engine over?
