Lock Relay (discontinued)
SSClassic
109
114
Pennsylvania
where can we get these,i looked everywhere online & their all discontinued RY547_FULL.JPG RY547_TERMINAL.JPG RY547_TOP.JPG
SSClassic
109
114
Pennsylvania
i put in the RKE from a 99 monte,everything works as it should but the locks seem weak when using the remote and wont fully lock/unlock.now if use my door switches they are fast and work great,probably not the relay at all but mine looks like its been to hell & back lol figured it wouldnt be a bad idea to have one on hand since their discontinued now even if it used.ive had to clean my hot terminal from the fuse box and that terminal is a bit loose
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If you door locks work properly with the door lock switches then I would say everything is working properly so it must be an issue with the module for the remote door locks. If you have a good battery in the fob I would look at the antenna for the remote first and if that's ok I would check the wiring
