Hey all,
I did some searching here and other places but still have a few question I thought you guys could help with. I am at the point of running new brake and fuel lines on my 1986 Monte Carlo. The body is off the frame so I have the perfect opportunity for this.
I picked up 3/16" and 1/4" cunifer for the brakes and was thinking of using it for the fuel system as well. I have the old lines which look like a feed line and a return line on the passenger side and a vent (I believe) on the driver side. Do I need to use the vent line on the driver side or is there maybe a better idea? As for the feed and return, I need to run an electric pump as the L29 454 carbureted engine I have does not have a provision for a mechanical pump. Will 3/8" cunifer be sufficient for the feed line and should the return line be smaller? What would you recommend for a fuel pump? I don't need the best but out there as I am on a pretty tight budget. The engine is pretty much stock but I might add to it later.
Thanks for your help...
