Been a while since I’ve been on, but I’m having an issue with my LeMans. Started last month, would be randomly driving along and it would just shut off like someone reached over and turned the key off. Wait a bit and it would be fine and then happen again. Would get to the point where it just wouldn’t start (turned over fine) until a long while. I replaced the ignition coil thinking maybe it was getting hot. Did the same thing. I ended up having it sit for about 3 weeks because I’m in the process of buying a house and just haven’t got to it. Today I went out and checked for any obvious loose or damaged wires and didn’t see anything. Went to try and start it and the battery is completely dead so I figure there’s a short or something somewhere that drained it and is likely causing the original starting issue. My real estate agent has a mechanic background and said I should check the fusible link on the starter wire. No damage or anything there. Anyone experienced anything similar and give me some tips on where to start? I’m not great with the electrical stuff.
