Low On Blinker Fluid - Left Side
ed1948
1,286
1,613
Quinte West, Ontario
86 Monte Carlo SS, stock - I topped up the fluid
During the winter I had the fuse box out as well as all lights removed from the car. I just put everything together. Now the left turn signal flashes once every 30 seconds. Right side is good. Grounds are clean and measure good, 4 ways flash normal, marker lights ok, parking lights ok, left front and rear bulbs light up,, reverse lights ok. trunk ground good,
I'm looking for something stupid I did. I have the manual but it doesn't explain an extremely slow blink.
Ribbedroof
4,861
6,888
Wellston, OK
Correct bulb?
ed1948
1,286
1,613
Bulbs? I assumed I put them back as originally. I'll check them ...thanks.
I'll swap them left to right and see.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
You must have parked you car on an angle, turn your car around and leave it over night. The fluid should drain back in....:D
if one side is slower than the other that means more resistance in the slow side, could be a bad ground, incorrect bulbs or defective sockets
ed1948
1,286
1,613
Ribbedroof - you are the first to answer the question correctly. - wrong bulb!
Last year when I took the lights off one bulb broke and I replaced it from my box of bulbs. Close but it wasn't a 2057, it was unlabelled.
Thanks everyone for their help. Now my blinker fluid is evenly distributed left to right.
I might add that I should follow my own advice when it comes to troubleshooting - start with the easy things first. aka KISS.
  • Informative
  • Winner
mheath717
413
19
Florida
Its funny you mention the simple things. I purchased an 87 Regal about three months ago. Right turn signal worked normally. Left signal would make all lights flash as if hazards were on. When I pressed the brake pedal, the front parking lights lit up. I was thoroughly confused.
End result was a single filament 1156 bulb in the left rear housing where a dual filament 2057 was supposed to go. Changed one bulb and all my problems went away. Now I can safely turn left without confusing everyone! Lol
Sent from my SAMSUNG-SM-G935A using Tapatalk
mudpaws
Oct 26, 2010
99
26
Long Island, NY
Yes. ALWAYS always check the simple things first! Man, can I tell you the electrical nightmares I've seen people create over the years, then they take them to ME :eek::doh:
