Lower ball joints
Dylan88
152
Any tricks?
Doing spindles and got new ball joints (moog) and got the lower one in with a press took a long time very tight but noticed its not 100% flush the one edge but best could get with the hand press. Will it be ok and seat itself eventually ? Kept going in crooked but kept trying different angles and got it pretty good
UNGN
3,061
Southlake, TX
You can try heating the arm with a heat gun while you press. Sheet metal arms are much easier to press BJ's into than the forged steel arms on my Jags.
Reactions: Dylan88
scoti
628
Texas
Wont hurt to hammer on it abit ?
Don't beat on a specific area. Put something (wood works well) between the edge of where your going to hit it & the hammer. Move around each time you see movement. You don't want to force it if it's in a bind. Try & keep it as even as possible when using force from impact.
UNGN
3,061
Southlake, TX
I use 4X4 wood blocks and my $150 20T Harbor freight press.
I only use a hammer on ball joints if they spin while I'm trying to unscrew the nut AND I'm throwing them away. It is amazing how well a few taps from hammer stops a ball joint from spinning, which also means its stops the ball joint from working properly.
Dylan88
Thread starter
May 31, 2018
152
Far as I got it posted a pic . Any idea
Dylan88
Thread starter
May 31, 2018
152
Hammer it in and the other side will come out and look the same
G-Body Performance Upgrades
