Lower ball joints
Dylan88
160
22
Any tricks?
Doing spindles and got new ball joints (moog) and got the lower one in with a press took a long time very tight but noticed its not 100% flush the one edge but best could get with the hand press. Will it be ok and seat itself eventually ? Kept going in crooked but kept trying different angles and got it pretty good
UNGN
3,048
3,264
Southlake, TX
You can try heating the arm with a heat gun while you press. Sheet metal arms are much easier to press BJ's into than the forged steel arms on my Jags.
scoti
1,972
3,385
Texas
Wont hurt to hammer on it abit ?
Don't beat on a specific area. Put something (wood works well) between the edge of where your going to hit it & the hammer. Move around each time you see movement. You don't want to force it if it's in a bind. Try & keep it as even as possible when using force from impact.
UNGN
3,048
3,264
Southlake, TX
I use 4X4 wood blocks and my $150 20T Harbor freight press.
I only use a hammer on ball joints if they spin while I'm trying to unscrew the nut AND I'm throwing them away. It is amazing how well a few taps from hammer stops a ball joint from spinning, which also means its stops the ball joint from working properly.
Dylan88
160
22
Far as I got it posted a pic . Any idea
