Lower front control arms
ssiron
Mar 28, 2010
50
8
Sweetwater, Texas
Where can I find new front lower control arms. Moog does not have, the ck series, the good ones anymore even the s10s. Looking for some new bare arms such that I can use the good Moog parts to build. Could even use the s10s. Can not find complete lower control arms other some off brand s10s, even the Moogs. OPGI has some but they're $ 100 each?? Used ones are to expensive to ship?
Frank
WTxSS
melloelky
4,157
9,552
mass
Check on rock auto under 1982 s-10 they're some well under 100$
If you go the used route,check them over especially around the ball joint area for any stress cracks.the last thing you want is a failure like that.
ssiron
Mar 28, 2010
50
8
Sweetwater, Texas
The moog parts are the rk series, says non serviceable, reviews are not high on these?? They also have a delco brand for about the same price but i don't know if they're "serviceable". Rock Auto shows them as daily driver not economy like the RK Moogs. I was really looking for the higher grade moog, but they only have the right one, left one is unavailable. Has anyone installed the s10 arms and drilled the front chassis mount for the 14mm bolt the s10 uses?
melloelky
4,157
9,552
mass
I'm guessing the "non serviceable" means the joints aren't greaseable?i don't have any experience with these arms per say but back in high school my dad and i rebuilt my stock arms.that was a set of clapped out stockers and it went fine.you said you were looking for a set of bare arms to put some moog parts in,why not buy the right side that you've been looking @ and pick up one for the left and build it to your liking?
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,183
Upstate NY
One of the up sides to a of the circle track guys that have rules requiring metric GM G-body chassis is that these parts are still in production. I can drive 5 miles to the local speed shop and buy them off the shelf. I believe AllStar Performance has them available.
Part numbers are 57804 and 57805.
UNGN
3,048
3,264
Southlake, TX
If I was buying new arms, I personally would swap the balljoint with a proforged 1/2" taller joint from summit ($50/each), anyway.
A taller lower ball joint improves steering geometry (reducing bump steer), Improves handling (by improving the camber curve) and lowers the car about 3/4" and the proforged balljoints are greasable.
There are just too many upsides to swapping the balljoint vs keeping the originals.
