lowered front and 235 60 tires
mickeypowa
146
38
Tahiti - French Polynesia
Hi !!
I changed my front tires recently by 235 60 15 (the original tire size I think ?) but now the tire hit the frame. It's because the front of my car has been lowered I think.
I would like to keep theses tires without trimming, so I would like to go back to a stock height. How can I do ? What parts should I change ?
The springs, and the shocks ? other parts ??
Do you have the references so I can order on internet ?
Thanks a lot !
Mickeypowa
Winkernod
139
259
London Ontario
My 1980 Grand Prix is at stock ride height but when I put 235-60-15 on it the inside scrubbed slightly so I had a pair of 1/4 inch spacers that fixed the issue
PBGBodyFan
792
1,223
Wisconsin
Hits with normal driving or on full lock turns?
mickeypowa
146
38
235 60 15 isn t the stock tire size ?
It rubs the body frame at full lock turns, but a lot !
Actually I bought the car already lowered with 225 50 15 tires. So I didnt do a wheel alignment.
But as the roads here in tahiti are pretty bad, I would like to have stock height and tires to have a more confortable car.
And I prefer the standard height aesthetics.
What should I buy?
Moog springs ? Which one ? And shocks ?
Or also other parts ?
MechMan
337
139
Kingsport, TN
I know that the stock tires on a 1986 Monte Carlo SS were 215/65/15. I don't see stock for yours being too much different though I am not sure what you have. Looks like a Grand Prix from the picture.
9,162
15,340
I had a few years between putting in new springs (non-A/C SS listing) & putting on the 235/60/15's with the change vrom a V6 to V8. There was never any rubbing with the tires & the inner fenders/wheel lip. The only factor that could be different for me was I used mid '80's steel rallys that had a different a different offset than the stock 14's & let the wheel wieghts hit the lower control arm. Might want to see if it's the offset is the cause.
mickeypowa
146
38
Ah yes I have not the stock rims too. 15 inch but I don't know the offset.
But in fact the tire is too tall and touches de metal of the frame. If I put a spacer the tire should be stuck against the frame.
I switched to 205 60 15 and now I don't rub anymore, but I m not satisfied of the aesthetics.
What coil springs and shocks would you recommand for my oldsmobile cutlass supreme 1980 ?
Should I change the control arms etc too?
The photo is with my new 205 60 15 !
Oldcoyote
14
16
Hi !!
Thanks a lot !
Mickeypowa
How was the front lowered?
9,162
15,340
Hate to see you wasing money of tires but a 215/65/15 might be what would work for the aesthetics. This is the stock 15 inch tire for our cars (MC SS, 442, GN, 2+2).
