i should ask when u lower the rear do u automatically use a shorter shock?Peter said:depends what "harsh" is. if harsh is the shocks running out of travel then yes you need shorter shocks. if harsh is referring to the spring rate then that is all tied into the springs you selected
they are the belltech lowering springs from summit bel-5118pontiacgp said:I doubt your shocks are bottoming out since if they were your car would be bouncing cause the shocks would be destroyed. Plus bottoming out doesn't give you a harsh ride, it gives you a bang. What's the spring rate of your springs? I used a shorter shock cause my rear springs would fall out when I jacked up the car.
1986SSMC said:pontiacgp said:I doubt your shocks are bottoming out since if they were your car would be bouncing cause the shocks would be destroyed. Plus bottoming out doesn't give you a harsh ride, it gives you a bang. What's the spring rate of your springs? I used a shorter shock cause my rear springs would fall out when I jacked up the car.
def ill have find out thxspontiacgp said:1986SSMC said:pontiacgp said:I doubt your shocks are bottoming out since if they were your car would be bouncing cause the shocks would be destroyed. Plus bottoming out doesn't give you a harsh ride, it gives you a bang. What's the spring rate of your springs? I used a shorter shock cause my rear springs would fall out when I jacked up the car.
That says nothing about the spring rate. I'd be asking them what it is
