I'm gonna post this up so it may help some people.
Bunch of LS Engine Wiring Harness schematics here:
Here is the diagram for the Gbody Firewall Bulkhead Connector:
I posted the link for the schematics in reference to what some people may have as "standalone harnesses" or you build your own, can use the schematics to double check what you have.
The wiring on the Firewall Bulkhead is simple:
Two 12ga RED wires are 12v battery wires coming in off the battery POS cable at the starter, they have fuseable links on them. These both go into the ignition switch on the column.
Single 12ga PURPLE wire is from the ignition switch on the column to the starter solonoid to start the car.
Single 12ga PINK wire is the 12v Key-on Ignition wire to the Distributor.
Mentioning them above because they are important. The rest are labeled as such. Leave the lights and horn wiring alone.
EFI LS Swap is simple.
Keep the two RED going into the Firewall powered from battery POS 12v. They do not have to be connected to the starter if you install a fuse box that connects to the battery, and has outputs that are constant battery power. 12v battery outputs on the fuse box can be spliced to these two wires going to the Firewall. Would be wise to have a fuse on them somewhere if the fuse box doesn't.
PURPLE 12ga needs to stay from the Firewall Bulkhead going to the little peg on the starter solonoid.
PINK 12ga wire gets connected into any circuit that needs 12v key-on ignition power.
All the wiring that is connected in the existing SBC/V6 Engine Harness can be clipped and re-purposed since you're installing the LS EFI Harness.
I used that wiring and built several circuits that I needed depending on how I ran wires.
I make it sound simple, there not much to it as long as you understand a wire has two ends. The rest is up to you how you want to do it.
I installed the whole fuse box out of a 1998 Camaro into my SS, spliced in the fuse box into the existing factory Gbody firewall bulkhead wiring. Since it was a GM fuse box all the colors matched. 4ga wire from the battery ties into the fuse box to give it 12v, from there I connected the two RED 12ga wires going into the firewall bulkhead. PINK 12ga coming out connects to the Pink wire on the fuse box 12v key-on Ignition circuits. PURPLE 12ga goes to the Starter through the engine harness. My LS engine harness plugs into the fuse box portion that connects to the wiring for the LS Engine & PCM. I also have a connector inside of the car to run the gauges and to the OBDII DLC.
That's pretty much it. 👍
