LS starting problems
M
My Camino
29
12
8
#1
601514b1-3484-41b4-8dc6-63307e7d258e-jpeg.88536
Hi. Just tried starting my LS that I installed in my 83 Camino, and I can’t get it to start yet.
The fuel pump primes, and I have fuel at the Fuel rails. I checked the pink wires to the coils, and they have power.
I am a noobie to these LS motors. So I am looking for some help troubleshooting why it won’t start. Not sure what else to look for and check
Thx
Shannon
O
ostrich
Aug 27, 2012
98
59
Ontario, Canada
#3
Sounds like a VATs problem. If you have a 'Noid' light unplug one of the injectors crank & see if you get a light. Won't get an injector pulse if VATs is still enabled. Same if the crank sensor isn't hooked up. Ask me how I know
M
My Camino
29
12
8
#4
Does it start and die?
Is the VATS disabled in the tune?
Are all the unused vacuum ports plugged?
It won’t start at all. I did send the computer away to lt1 swap to have my computer done
M
My Camino
29
12
8
#5
I will try and track down some noid lights
The computer was sent to lt1 swap.
Texas82GP
Texas82GP
4,589
7,359
Spring, Texas
#6
M
My Camino
29
12
8
#7
Thx for answering
I just went and bought some noid lights
When I turn the car over, there is no flash. But when I release the key it flashes once.
The ports are plugged. And the computer was done by Brendan at lt1 swap
M
My Camino
29
12
8
#8
M
My Camino
29
12
8
#9
I just tested the pink wire for the coils. And they have power with ignition. But nothing when the engine is being turned over
So no injectors or spark while being turned over
