Ls swap 1 wire alt question
DPF 84 Hurst
47
13
8
Hi, can’t seem to find an answer on this that fits my swap… please help. I have a LS1 (98) with 1 wire alternator I have it installed in a 1984 hurst with rally gauges I would like to know how to get the volt gauge to work … what wire or wires do I keep from the stock alternator wires? Is the original gauge even reading out of those wires that went to the original alt or did it read voltage somewhere else ….the more I’m reading online the more confusing it is getting
Thank you
64nailhead
Goat Herder
Dec 1, 2014
5,708
12,215
Upstate NY
It’s not reading voltage from alternator. I believe it is one of the 12 gauge wires coming from the fusible links on the starter than run through the factory pass through below the wiper motor.
xylorex
305
395
New Orleans, LA
i put a 1-wire alternator on my 87 k10 truck, volt meter still works. i've just got a wire run straight to the battery from the alternator, no other changes. original alternator plug is zip tied to a hose.
