Hey everyone!
This winter I did a LY6 6.0L LS and T56 swap into my 86 olds cutlass. Once tuned it should make around 450 to the wheels if not closer to 475. It has a spec twin disc clutch in it. I am having a hell of a time trying to get the car to launch at the track. Generally just spins. at anything above 3500 and bogs under 3500 and unloads rather violently then spins. Car has a 2 step wired into the clutch pedal to control launch rpm. Tried tire pressure from 12 - 18psi which did not make a big differenc. Either spun or bogged then unloaded. Best 60' was about 2.20 seconds but average was around 2.50 seconds when last year I was running 1.70 seconds 60' with the SBC 350 and TH350 trans. Currently it has 235/60R15 MT E/T street drag radials on it. From what I have read so far they will not work well with the manual transmission and I need to go to a bias ply slick. No problem there will order them in the next couple weeks but I am also curious about springs and shocks.
I do not know if possibly the violent launch is due to the short OEM pinion snubber that is in there or not?
Currently it has some cheap KYB gas-a-just shocks in the front and rear that are maybe 4-5 years old. Springs are 2" drop springs in the rear and 2" up front from somewhere online but basically nothing race or performance oriented and were rather cheap if I remember and also 4-5 years old.
Rearend is a Ford 8.8 from an Explorer that was narrowed and centered and had all the g body brackets welded on in a jig. Also has UMI tubular adjustable control arms upper and lower, and has a 2002 Mustang GT sway bar. I think like 24mm.
Drilve line angle was right around 3* down and I think pinion was up 1*. Not sure if because of the tubular control arms I should now make them match?
Where should I start with this? a lot of people I have talked to and research I have done on this forum and other say definitely a bias ply slick and adjustable shocks. Figured probably different springs as well. HAve an issue right now where it seems like it is leaning to the drive side ever since I did some hard pulls the other day.
The only thing to consider is that this is a street car. I do plan on driving it on the street, and driving it to the drag strip as well as possibly going to some road course events as well. Sort of a triple threat car.
Where do you guys think I should start? I see a lot of people like the bilsteins but I was not sure since they are not adjustable if I should get them or not.
thanks!
Shane
thanks!
Shane
