Ls3 with a holley 750 HP on the street
LsxBuickRegal1982
133
128
I have a Chevy performance CT525 crate engine with a holley 750Hp double pumper and a howards cam for a weekend street driven ls swap 82 regal and I was wondering would this carb be too much on the street I am running a GM single plane intake and a Howards cam.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
What trans?
Chevy recommends a 650 for that engine but tested it with a 750.
So the Dyno numbers on the sheet used a 750 Holley
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
A basic rule is vacuum secondary's with an auto
Mechanical with a manual
But that said I usually use a mechanical secondary carb
bracketchev1221
1,411
1,647
You'll be fine with the 750. It has enough gear and converter to help get it going.
vanrah
879
1,189
Near Afton, Wisconsin
Greetings LSx82 & all; I really like the cam ya picked & the intake. With that carb you may find ya got a little flat spot going full on from a slow roll. But like Bracket Chevy & Turna said you'll be fine for an all out on the converter start. Good Luck & if ya got carb questions just ask us guys, Ole' Bopb
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Reactions: 4 users
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,809
Louisville, KY
Carbed LS isn't bad, but so much more efficiency, power, tunability is on the table with EFI. Not to mention, some EFI setups look wicked :sneaky:;)!!!
