LT1 into 84 Cutlass
Verz
31
Wichita KS
Have an 84 cutlass minus motor and trans and was planning a rebuild. My initial plan was for a supercharged 350 but now im planning on an LT1/trans swap. Car started as a v6 but had a 350 swapped in. Any idea how easy/hard this swap would be and what would be needed.
SBCregal
261
computer, harness, fuel lines, tank, pump, ignition, sensors, probably a transmission crossmember to start with. sounds like a good project. alot of work and alot of parts im sure.
85t5mcss
343
2
Indy, IN
Very good project. (Not intended to spoil your fun) This has been done b4, this is a good thing. Plenty of help on the net, just google it. Also take a look at MonteCarloSS.com What goes for the Monte also goes for the Cutlass.
Verz
31
Wichita KS
yea know its been done just like the idea of better fuel economy and throttle response. Prolly just find a wrecked LT1 fbody or caprice and raid it for parts i need. Thanks for the help and ill go check out that site
85t5mcss
343
2
Indy, IN
That's the best way to do it. And I hope I didn't offend u. I am with u on the whole MPG and performance aspect. So many parts r available now for the LT and LS series engines.
Verz
31
Wichita KS
not offended at all, and i really do appreciate the help
Bubba
n00b
Oct 6, 2006
4
I'm doing a 1994 Z28 motor and T6 into a 1985 Regal
The clutch pedal was the biggest pain in the butt.
The engine,radiator and trans pretty much fit right in.
http://img.photobucket.com/albums/v449/ ... 000362.jpg
http://img.photobucket.com/albums/v449/ ... 000365.jpg
I still have lots of things to finish, power steering hose, exhaust ,shifter ,coolant plumbing, fuel plumbing
http://img.photobucket.com/albums/v449/ ... 000364.jpg
right now a pencil might fit between the a/c clutch and frame rail
Unless you have another car to use and don't need your car, don't even think you can do it in a week or something like that.
If your cutlass is a spare car and you got the money to do it, go for it and figure $5,000 to $10,000 depending on what you pay for a wreck and how many new parts you pour into the project.
http://img.photobucket.com/albums/v449/ ... /buick.jpg
what the hell, I'm riding on 70's Camaro wheels, might as well have a 90's camaro driveline :p
feel free to ask questions. People on the internet helped me get this far on it.
Jman
203
2
Ontario
Bubba, things look sweet. I did the TPI swap w/ 5speed. Wish I had found a 6speed, but thats on the list now.
Bubba
n00b
Oct 6, 2006
4
Thanks Jman
hint Verz
get a black felt marker
buy a box of ziplocks bags and bag the nuts and bolts from both cars and mark the bags
trans bolts
O-trans
C-trans
o-for oldsmoblie
c-for chevy
bell housing bolts
cross member bolts
starter bolts
o-starter
c-starter
and on and on.
You could throw all the olds cutless nuts and bolts you think you will never need in a box or bucket and than go dig threw them all when you find out you do need one of them :cry:
bag and mark them all from both cars
get masking tape and mark every wire and connector.
the few minutes here and there on the disassemly to mark the stuff will save lots of time when it comes to putting things back together.
