Has anyone used one of these cams & care to offer your experience?
I was gifted a used 400 from a buddy that passed last year (817 2-bolt block, dished cast pistons, Dart Iron Eagle 200/64cc, Eddy Perf RPM, 1 5/8 headers, 2.5 dual h-pipe exhaust out of a 71 El Camino).
A buddy & I tore into the motor recently & found it's in need of some love. Seems it saw some excessive juice more than once & was missing 1/4 of the crown on one piston (yet still had cylinder pressure when we tested LoL).
Since the OE 305/2bbl/th350 in the Bu isn't exactly a threat & gets about 10mpg w/city driving, I'm toying w/the idea of going to a local rebuilders I've used before & get a fresh short block w/flat tops vs. the dished pistons @ no difference in the cost. This is a very budget deal w/parts already on hand & I'll use some new/old AFR 190 Street heads w/74cc combustion chambers. I've been researching cams & when doing the engine calcs, I get within 10hp using one of these Lunati EFI flat tappets vs budget (Howards) Hyd Roller spec cams. The flat tappet approach is <$250; the HYD Roller ~ $725. The one that seems to be the right fit: 280/290 ADV; 230/240 @.050; .489/.520 w/1.5's; 112LSA/108ICL.
This would be a 100% 'street/torque' build. No racing intended/expected.
