LY6 and TKO 600?
M
Muswagon
45
8
Is anyone running this combo?
I already have the ford TKO and know what QT bell and clutch I need, and the hydraulic TB bearing (Tilton), and I got a good deal on a LY6 so I am committed to an LS now I spoz
I had searched and found a trans crossmember that would work, but I cannot seem to find it again...Any insights?
For clutch pedal, I have been looking at the sick speed monte kit, which uses a F body master, which should work with an internal slave.
Lastly, do most go with auto because just reading back what I have written manual seems like a massive PITA? I just prefer a manual so I willing to give it a shot
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
26,547
Kitchener, Ontario
I have the F body master clutch with the McLeod hydraulic throw out bearing, the instructions for 3/4" bore is pedal travel of 1". Your throw out bearing will have pedal travel instructions. I use an applicance foot adjuster with a nut on each side of the firewall as an adjustable pedal stop
M
Muswagon
45
8
What pedal did you go with?
Thread starter Similar threads Forum Replies Date
FastCraig G-Body LS Swap 8
M G-Body LS Swap 17
