M/t radial issue
Tc77
Sep 19, 2018
72
189
33
I installed a set of Mickey Thompson’s street radials on my car and redid the rear now cruising at 70 plus. Get a vibration in the seat. I have had the tire balanced twice no help. change from a posi unit to a truetrac cut the axle ends off put a set of big bearing ford ends on.axle go in and out with no effort. Is this normally with these tires or is there something wrong? Any help would be appropriated.
UNGN
3,048
3,264
Southlake, TX
Put the rear on Jackstands and take it up to 130 mph. If the tires aren't visibly bouncing,, Look at the tailshaft bushing in the trans.
1,167
2,638
West Virginia
Try a different wheel tire combo?
1320John$$$
951
2,043
Pennsylvania
Did you check your driveshaft angle if its 0 degrees or less then 3 it will feel like tire balance
Tc77
Sep 19, 2018
72
189
33
I bought a new angle finder. Should have it this week . Will recheck drive shaft angle and drive shaft for play. See what results I get from that
scoti
1,959
3,365
Texas
Are yours the 'street radials' or what line?
I has a buddy go through this w/multiple sets of sticky Micks on his GT500. Put the original wheels/tires on.... No issue. Sticky Micks & vibration/wobble. Definitely could be felt more @ certain speeds. We he discussed it w/me & we poked around, it appeared to be separating where the width meets the sidewall. I know he got a 2nd set from them & I recall they were problematic as well.
I'll ask him what happened in the end & share what his outcome was.
