m/t radials
one99lives
n00b
Feb 10, 2019
2
so I just bought M/T street slicks yesterday and the size is 275 and width is 11.4.so just wondering what size of rim will I need so I don’t rub and also what would the rim width be that I’ll need and the offset
bracketchev1221
1,412
1,647
What is the tread width of the tire? Not the section width. Off the top of my head, an 8" wide wheel will be what you need. As far as offset, well it could be 4-4.5" backspace.
9,614
12,683
I would also say a 8" rim with careful attention to correct backspace,
The Cutlass has a squared off wheel well which can limit tire size especially on a lowered car or one with drag shocks and the rear squats on take off.
lilbowtie
3,460
3,965
Canton Mi
Do it mathematically - decide what rim your going to use (recommended width) I believe that is section width your giving us (11.4) So if you run an 8in rim the section width the tire will be 3.4 inches wider than the rim or 1.7 inches on both sides. SO, you have approximately 5.5 inches from your drum to the frame. 1.7 inches plus 3.5 back space is 5.2 inches - pretty close. You might be able to go 4 inch back space since the lip of the rim gets measured in back space, but it will be tight. I run an 8 in rim w/ a 11.4 section width slick and use 3.5 BS
