Opinions Wanted!
Guys,
The 4L65E in my truck is dead, again. It failed on a wide open throttle 1-2 upshift Wednesday morning, on my way to work. I think it shattered the output shaft, since it is leaking transmission fluid out of the tailhousing seal. It has been built twice in 50k miles. At 120k the 3-4 clutches were toast. At 135k the input shaft was pulling out of the input drum and was leaking pressure, which resulted in burned up clutches. I'm not sure I want to fix it again. I'm considering a 4L80E swap.
My truck is a 2008 GMC Sierra regular cab, short bed, two-wheel drive. It has a 5.3 with the GM LS Hot Cam, headers and a tune. It has 4.10 rear gears with 32" tall tires. I'm guessing it puts out maybe 400HP and 400ft. lbs. at best at the flywheel. I'm guessing it weighs 4500 lbs. (based on internet research). I'm keeping this truck (presumably until I croak) and a more powerful engine in the future (after the Grand Prix runs and drives) is not unlikely.
If I were to go with a 4L80E, I was considering just mail ordering one that is already a performance build, for the convenience. The sky is the limit on price though. I don't think I want to spend $5k on a mail order transmission.
I have a buddy that manages an automatic transmission parts house on the other side of town where I grew up. He knows several builders. He can help me line up the parts and a builder to beef up the 4L65E some more or to build up a 4L80E. He sent me a parts list for an 80E build. It's $900 without hardened shafts. If I spend another $1200 (random number in the range I've seen) on a core, then I'm $2,100 + money for the builder into it which is pretty competitive with the mail order transmissions, especially considering I don't have a core. Then I need a flexplate, torque converter, lower bellhousing, dipstick tube and indicator, shift cable bracket, etc., etc. An 80E swap will be expensive but I'm up for it since I'm keeping the truck.
What I don't want is to spend another $2k on the 4L65E and break it again, or to spend $3k+ on an 80E swap and break that when another $500 spent would have made the difference.
A few questions for you guys:
1. Is anybody on here running a mail order 4L80E? If so, which one and what has been your experience like? What is your power level and how hard do you drive it? How many miles?
2.How strong is a stock 4L80E?
3. Should I be worried about a hardened input shaft or output shaft or other key hard parts in the 80E? I can't imagine ever putting north of 600HP in the truck and closer to 500 is more likely. I've been thinking along the lines of a naturally aspirated 370 c.i. build or maybe even a 408 stroker in the future.
4. If it was your truck, what would you do? I drive this thing pretty mercilessly and I'd like for the transmission to be able to take it for over 100k miles before needing to get back into it.
I guess what this post all comes down to is, how much beefing up does an 80E need? I'd like to do this and be done so I can move on to my car and other things.
Thanks in advance for any input.
Best,
Jared
rated for 650 ft. lbs. and I like the price, but B&M scares me....
https://www.summitracing.com/parts/bmm-118002/overview/
these guys have some pretty nice looking stuff but can get pretty pricey when you +core +shipping +hardened input shaft....
http://www.finishlinetrans.com/transmissions/index.htm
These guys have a great internet reputation but ghastly expensive....
http://www.jakesperformance.com/4l80/
These guys are out there but I've read/heard bad things....
https://www.monstertransmission.com/4L80E-Transmission_c_3936.html
Guys,
Best,
Jared
