About 6 years ago I got out of the game after I wrecked "Malibu1" so I parted it out and sold "Malibu4". So July of last year my dad saw this '82 & I had to have it...i prefer '79s but this was too nice to pass up. So to piss my wife off :lol: ...i bought it. My first v6 car.
'82 alldoor 229/th350c/2.41 with 54k on it
here is the pics when i first got it
Rather then post every single picture I have off every progress...i will initially list out what I have done & post pics of the highlights
In no particular order;
-removed all smog equipment
-custom midlength headers (damn near equal length)
-custom dual 2" mandrel-bent aluminized exhaust with merge X-pipe, now currently with the largest stock-style mufflers I can fit under the car
-modifed '80 229 air cleaner with dual snorkels (80 uses a taller filter)
-Summit roller-tipped 1.5 rockers (was worth 2 tenths!)
-clutch fan in place of the fixed fan (came off one of the past malibus)
-SpeedHut 6k tachometer
-70amp alternator
-Taylor wires
-rebuilt 200r4 with a shift kit,
-stock replacement Grand National torque converter (about 2100 stall)
-Lokar rod-type shift linkage (to run 4 in place of 3 on the column)
-AllStar trans cooler, with Summit -6 puck-lock lines & AN fittings
-Iceman chromoly crossmember
-rebuilt 7.5 rear with TrueTrac LSD, fresh Allstar 3.73 gears & poly bushings, TrickFlow cover, T-type Aluminum drums w/ all new rear brake hardware
-Autofab tubular rear control arms & custom welded in braces
-front F41 'jounce' bars
-fender to core braces
-F41 front sway bar w/ poly bushings & links (have rear...but been to lazy to paint & install)
-Sensatrack shocks
-AutoPal E-code headlights with Hella yellow high beam bulbs for the inners
-aluminum tag bucket
Whats not installed yet, but own...
-Crower cam 256/264 .411/.427" lift thats been WPC treated
-new Speed pro lifters with the bodies WPC treated
-Harland Sharp 1.5 aluminum rockers
-Holley 390 4bbl
-Edelbrock performer intake
Future plans...eventually I want to boost this motor, or get a 200 to build up for boost. Not necessary after big power, more to show off my fab skills & to have something different at the cruise in
Current dynograph ...the red is shorter due to 200r4 downshifting at any lower rpm. 108 is headers & duals, stock rear and trans, 111 is with no air cleaner. 116 is dual snorkel air cleaner, roller tip rockers & 200r4/3.73s
Best timeslip (#2). This is not a racecar, just a toy. When basically stock with just duals & flex fan it ran 17.3s
-70amp alternator
-Taylor wires
-Sensatrack shocks
-Holley 390 4bbl
