- Oct 16, 2020
- 46
- 8
where does it connect? if you see pic its not connected once i got my engine replacedThats an oxygen sensor in your exhaust manifold.
thanks you much. my car is 82. most agree that should not need it. i was just curious of what is was and where is the connectionWhat year is your ride? Being u swapped motors u may not need it. I have an 86 MCSS that has the same sensor. I will take a look om mine nut because of work i won't be able to look at mine and send a pic to u. I can Thursday if that helps.
