Manual Transmission Swap SBC 88SS
KCEE442
112
16
Long Island, NY
Been doing a bunch of reading on the swap and have just about everything i need, have a t-5, pedals, mechanical linkage, clutch, flywheel etc.. only thing im reading is that i need a specific bellhousing, i currently have p/n 460486 (new p/n; 14061655) believe to be out of a truck. Anyone know if this will work if u get the correct clutch fork?
Thanks in advance!
rwd_pete
108
86
Niagara Falls
Thanks in advance!
This is a good resource.
http://www.garage-scene.com/t5-into-ag-body/
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
The stock G-body bellhousing that is most common is the Chevy '606' for a 12-3/4" flywheel (153 teeth) - uses the 'bent' clutch fork. If your bellhousing and flywheel are from a truck, they are likely to be 14" (168 teeth). The clutch fork likely won't work under the floorboard of the G-body.
What did the trans come from? If from a Camaro, the bellhousing and trans mount were rotated about 18 degrees towards the driver, since the Camaro had a very low seating position in the chassis. The G-body and your truck bellhousing are meant to mount the trans in the upright position. You will have to fabricate a tilted trans mount to match.
I'll stop now and await further questions. Ditto on Garage Scene. I lucked out and parted a 1978 SS El Camino that had the 697 bellhousing, so I was able to use a 14" flywheel with 11" clutch in my coupe.
  • Informative
