My GP seems to be running great but I want to know why it is and if I have it set up correctly. With the Fast EFI it has a MAP sensor on the body of the unit. The MSD AL6-2 also has a MAP sensor. I have been reading about what MAP sensors do but I can't find info relating to my set up. I'm curious about the vacuum advance that I can factor in with the ignition box. With the MAP on the fuel injection adjusting the fuel according to what the engine needs does the ignition box upset the EFI's function with adjusting the vacuum advance according to the engine's needs. I read that vacuum advance is more critical to a carburated engine but they are comparing that to an engine with an ECU controlling the timing and fuel. I can sorta get my head around each system but I would like to know how each system affects the other so I can tweak each system if necessary so they play nice with each other...
thanks for any help but please do not confuse me by using big words...
